Currently reading:
What is the best pipe slice?
Discuss What is the best pipe slice? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I couldn't see another version od this topic.
In order not to buy every pipe slice make out there. ...
Does anyone have a preference?
I find even good old rothenburgers fail just a frequent as the cheaper makes. I jave tried wd40 and ot just makes it so it takes 1000 turns before it cuts.
Any advice?
Thanx
As for lubricant, silicone grease is what I find best as they not only keep the cutters lubed, but the silicone helps keep the water out of the components. I use a wee tub of fine grade silicone grease that I got from the USA via Amazon. Use it sparingly, as too much will do more damage than good and all the crap that comes off pipes will stick to the grease.
I heard the Milwaukee electric one was on sale... might not be good for tight spaces but good if you do a lot of cutting
I have one and it's too big and bulky for most retro fit installs. It's good for new installs where there's more space to use it. I've used mine about a dozen times in 2 years. The wee M12 batteries hold their charge for ages.
I have sprayed mine with AC90 for years. Seems to do the job.
I have a Tornado branded one which I think is a Toolstation brand. Doesn't seem to be any different to Kopex. The main thing is to remember you replace wheels when blunt and keep them well oiled and occasionally solvent clean them to get rid of dust and debris. Even the best one won't perform well without oil.
Wait another few months - they will be giving them away.
I would have to rate the Milwaukee pipe cutter the worst tool I have ever bought.
Come to think of it, I probably didn't pay for it.
It was probably given to me as a package deal with something.
Whatever - pile of junk
Never really thought about this ..got loads ..anyway the ones that I have had for years and use most days say on the side
' Rothenberger' pipe slice is that a help 15 and 22
centralheatking mind you I also use Monument cutter for 28 mm
etc
Kopex,rothenberg and monument last about one year for me. But a couple of years ago I started using Sabre from The Range, every bit as good, solid sturdy and only £6. Sadly I've only ever seen 15mm though but I love them. I can have three or four for they price of one of the above and works and last just as good. Cheap ones are mostly crap but Sabre are deffo a worthy competitor.
Reply to What is the best pipe slice? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
