Discuss What fittings are these please? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The one on the basin look like they need a demounting tool. What Brand is it please. And the supply is these fittings which looks like it's demountable but what brand is it please?
Top ones are original Hep2o and are not demountable the others I don't know but someone will
1st original hep2o non demountable. Tap con will undo
2nd polyfit , demountable.
as above and the top i think is heated up and melted and pushed together
The top one looks like the old Hepworth push fit slimmer stuff that isn't demountable.
The brass nut which is part of the tap fitting definitely looks same as Hepworth. Don't remember ever seeing the "HL" on the fittings though.
A junior hacksaw carefully used through the gripper will cut the fitting off
just cut it on the hep,put a insert in and a compression 15mm strait,then join on with copper
Reply to What fittings are these please? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
