Discuss What are my responsibilities? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Very short version.
Im a sole trader of only 10 months, but an experieced Plumber of 30 years.
Installed a bathroom for a customer, they wanted me to source everything for them and have it delivered directly to them, which l did, once everything had been received by the customer, they then paid me for the goods.
The bath had to be inspected on delivery and refused if damaged, customer inspected and signed as all was fine.
I inspected and fitted it 5 days later.
Bath was first thing to go in, and day after installation the customer started using it, despite the bathroom not being completed until a few days later, this didnt matter to me as they had allowed the silicone to set..
This particular customer was an absolute pain right from the get go but you put that aside and act professionally regardless.
Once they had been quoted, they then started making lots of demands about the fixtures and fittings not having this, but must have that etc, annoyingly none of this was mentioned when l went out to quote...
One of the things they were adamant about, was it had to be a very good bath, because they had damaged one once and it was a nightmare to get sorted...
On to the problem.
Customer inspected the bathroom, very happy, paid in full the same day, absolutely over the moon.
2 days later, 6 days after the bath had been installed and used several times, customer gets in touch to say its cracked and the shower is faulty.....I go over the next morning, the shower isnt faulty, it was user error and the bath isnt cracked, theres a little air bubble in the bottom left corner at the tap end, around the size of a 10p.
Told her ld never seen that when fitting, they said theyd not noticed anything all week either, it was just " there" that night.
Said l would get in touch with supplier, see if we could get a replacement.
3 weeks later, supplier has said no replacement or refund as they believe the bath has been dropped (😡), lve insisted on a manufacturer report and still awaiting that.
Customer is getting increasingly pushy.
I should replace and refit for free, its my responsibility etc, theyve reported me to trading standards, endless emails..
Ive explained lm trying to still get a replacement bath, its still ongoing.
Ive also offered to refund them for the price of the bath myself plus £100 for their disappointment, but none of this is acceptable to them.
My predicament is, what if the customer has done something to the bath?
What if the supplier refuses to replace, do l have to replace and refit for free?
I charged for supply and fit, both of which l have done, and on completion inspection the customer was happy and paid!
Theres a supposed 25 year warranty on the bath, but if the supplier says its been damaged they get out of that dont they?
Any advice appreciated.
Sorry for the long post..
Do you have a picture?
Have you looked under the bath to see if it’s a dent or surface imperfection?
If it’s a dent from above - something dropped and it wasn’t there during fitting or when the bath was inspected it sounds like they have caused it or possibly the tiler if it wasnt you
Hi
I inspected it myself the day after and its a small bubble in the acrylic that can be pressed in and out.
Its still intact, doesnt leak, no marks or damage whatsoever underneath the bath, l checked it over before l fitted it, and looked under again to inspect for leaks, its fully useable.
I was the only one to fit the bathroom, l do them alone, they had cladding not tiles, nothing was dropped in it when l was working in the area and l removed the protective film the day after fitting and cladding so that they could use it. It was perfect!
Sent photos and a video to the supplier, but its so small and so shiny that its hard to see, l had to rub a bit of dirt in it to make it show up..
If it's just the surface of the acrylic then polish it out or find one of these magic men who repair this sort of thing.
First though I would want the supplier/manufacturer on site and be there at the same time. Then go from there.
I know the horse has gone but your smart phone is your friend. Pictures of rooms under bathroom before you start, pictures of the room before you start, pictures as you progress and then lots of pics at the end.
As for customer being a pain, then get yourself a pad and pen and document any requested changes from the original estimate and get them to sign it.
Hope you get it sorted.
From the information given I think it's a manufacturing defect.
I've seen a number of cases like this over the years. The bottom line is that the unhappy customer can, and probably will, sue you in the small claims court for supplying a defective bath. Whether the root cause was your installation or the faulty manufacturing is irrelevant; if they get a supportive independent report they'll almost certainly win case against you and the judgement will include the costs of removing and refitting the the bath and bringing all the finishes back up to whatever standard a reasonable person could expect bearing in mind the price paid and what you promised.
From your point of view, you're entitled to a free replacement bath from whoever supplied it to you but expect them not to want to cough up for the labour needed to perform the transplant. From a business point of view the amounts involved are not going to be worth fighting over. The bath manufacturer may make you a good-will payment if you can find someone with responsibility for their reputation to talk to.
My advice is to not get tunnel vision and turn this into a fight between you and the customer. "The bath turned out to have a manufacturing fault that appeared after installation but the plumber got it replaced and reinstalled it out of their own pocket." is a customer experience that will boost your reputation and encourage them to recommend you to others.
The supplier has stopped replying since 3rd May after l requested a manufacturers report and after requesting they sent an assessor out.
I have pictures of before during and after installation, always do, but not of the room below.
The customer is fixated on a new bath, not a "repaired" bath.
All requested changes were done in writing via message, so l always have that written down.
Its really strange, but since they told me before l even went to work there about them cracking a bath before and it causing no end of problems..I felt uncomfortable. And l think if they had insisted on all the specifics at quote time, l wouldnt have put in a quote. Alot of them were very bizzare and took hours and hours to locate.
I took advice yesterday and was told that if the Manufacturer says its been caused by damage, then lm not liable, because the customer has always stated theres a problem with the bath, not that they think lve damaged it in some way, they are adamant that this bubble " just appeared " a couple of days after l had left site..
I appreciate your advice and reply.
One of my worries about jumping too early, is that if l just go ahead and buy a new bath and fit it, and then the supplier or manufacturer agree to replace the faulty one, then I have a bath at the customers address ( which they will highly likely refuse to take delivery of anyway) that l cant do anything with!
This is a situation where my 40% on materials comes in to assist. Helps cover returns to replace something under warranty.
Can I ask was it vp ?
I would agree with above about it possibly being a manufacturing fault. However a lot of manufacturers seem to spend more time finding fault with anyone/anything else. I often wonder whether the warranty is worth it as they always seem to blame the installation, sometimes justly sometimes not.
I would definitely try to keep communication open and explain you are in contact with the manufacturer, if it goes further the fact you have endeavoured to resolve goes a long way. My only concern would be as you charged for 'supply and fit' it may be the contract for the customer is with you and not the bath manufacturer, hence your responsibility. While hindsight is a wonderful option, especially with particular customers I would always supply them with a materials list and let them deal with it directly. That way failed deliveries/damage/change of mind etc is not on you.
Just remember it is a business you now run, deal with it in business hours, professionally and try not to let it effect other jobs or out of hours time.
Your contract is with whoever you paid to supply the bath. This is likely to be the stockist not the manufacturer who will normally be involved only as a matter of courtesy. If the manufacturer is not being helpful, you have to tell the supplier in writing that the bath they supplied is being rejected because it is of unsatisfactory quality. If they refuse to replace it you can sue them.
Although you'll have a winnable case expect to have to spend the equivalent of a couple of days seeing it through. (Collecting evidence, sending recorded delivery statements of claim, etc.) You need to make a business decision about whether this is a good use of your time and, unless the bath was very expensive, it probably isn't.
Local FE Colleges often have a "Setting up your own business" course that you can take as evening classes. They are not expensive and, if you haven't already taken one, you might want to see if there is one in your area.
As update
The customer started making very unreasonable demands via email, despite me only being given less than 3 weeks of toing and froing with the supplier of the bath, trying my best to get a replacement.
I finally offered the customer 2 options, as they were getting nastier and more persistent, threatening trading standards and legal action etc...
I offered a refund of the bath plus 25% so they could purchase a bath of their choice and l would fit it for free, or a refund of the bath plus £250 so they could pay a Plumber of their choice to refit.
Neither of these options were suitable, they are demanding the price of the bath plus 25% PLUS £600 and they want it in cash because apparently l cant be trusted with their bank details....
To put it into context, this bath is useable, it doesnt leak, the air bubble wasnt there when l left the job...
What next, let them take the legal route as lve offered a resolution???
Beat them to the punch Get trading standards involved yourself you’ve been more than decent
I always offer the " supply a list of what is needed and let the customer purchase " but this customer insisted they werent very good on the internet and wanted me to supply everything. Theyve now started questioning why if l charge ?£s per day, did they appear to pay £600 too much for the bathroom fitting 🙄
I explained that in a case of supply and fit, many hours are spent searching, sourcing, ordering etc, and unfortunately the customer has to pay for the service, afterall they were offered labour only terms and refused them...
Sounds like it was going to end up this way in the end even if the bath was fine
You want an independent evaluation as you’ve tried your best to resolve it
I don't think it's worth answering such emails punch for punch. Whatever you have charged on the invoice for the bath is the cost of that material. Show yourself reasonable, do it right as best as you possibly can, consult a solicitor if need be as to what reasonable would be, and if they actually bother to take you to court, so be it. They can only win a court case if you have not done your legal duties (your responsibilities, as you correctly put it), not just win because they are still dissatisfied.
As for expecting cash, that is reasonable if that is how they originally paid you, but you need a receipt then. Quite what you would do with their bank details (name, sort code, and account number) apart from pay money in is beyond me. (Try going to Tesco and paying by card and then expecting a refund in cash and see how far that gets you). You don't need to justify all this. You can merely say that you will offer the refund by the same method it was paid to you as that is your policy. If that isn't good enough for them but it's an offer that is within the rules of the law (which I expect it is), then how are you being unreasonable?
You can't please some people all of the time.
Thats good advice, thankyou.
Ive offered 25% over the price of the bath, and l charge £220 a day labour only, so offered either my time free of chatge to put their new bath in, or another £250 to chose anither Plumber to fit it, l said this would only be paid via bank transfer as that is how they paid, plus it is proof they have had it.
My thoughts are they will go down the small claims route, but surely, if l can prove l offered a resolution they would not approve a much higher claim in monetary value??
As covered above, sometimes you just can't win. You definitely don't need to justify the prices charged for materials, especially if they could of sourced them direct.
From what you have described above I would agree with Ric that constant emails are not the way forward. Keep a record of all communication and possibly send them a final note that you are waiting on the manufacturers to respond appropriately or your best offer would be 'X'. If it ever goes to court, the fact you are trying to find a solution goes a long way. If they chose not to accept it then that's their predicament.
Try to remember it is a business transaction and treat it as such, don't get personal or let it personally effect your normal day to day. If you've done the right thing they won't have anymore weight in court.
I think people often use taking people to court as a threat and too many people encourage the practice by settling out of court. If they innundate their solicitors and the court with irrelevant digressions (as it sounds they are doing with you via email), I doubt they will get very far. Not speaking from experience, mind.
Are you offering to source and install the replacement bath for free and refund (cost of the bath plus 25%) or you are refunding (the cost of the bath plus 25%) for them to source their own replacement bath which you will fit for free?
I can't imagine Pimlico making an offer more generous than that, so sounds reasonable either way!
Thats exactly what l did in my last email, repeated my final offer at a resolution and would continue my fight with the supplier myself for my own benefit, and my offer to them was irrespective of the supplier refunding/replacing or not.
I feel lve been more than fair, and it just feels like this customer is out to get whatever they can because they found a tiny flaw in their bath....
I have refused to source them another bath myself, because they have said they have reported me for breach of GDPR because l gave the suppliers their contact details as they needed them to deliver the bathroom....🙈
I said if l gave them back the price of the bath, plus an extra 25% they could source a bath of their choice and l wouldnt have to give anyone their contact details...
They really are pulling out all the stops..
And yes, on top, l would fit it for free, or give them another £250 to pay someone of their choice to fit it..
Dear Mr Judge,
My plumber fitted my bathroom. There was a flaw in the bath. The plumber offered to give me a replacement bath and fit it for free and offer me a discount due to the time wasted. At no time did I state that time was 'of the essence' (e.g. that the works had to be complete before my disabled uncle came to live with us). But I feel I deserve more.
Plus the plumber gave my address to a supplier that needed that information in order to deliver the goods I had agreed to order and I feel this breaches the GDPR rules of which I haven't read the 88 pages of PDF but I read something about it in the "Daily Mail" and quoting it makes me sound important. [To be fair, possibly there should be a document customers have to sign to ensure you can do that, but I'm sure 99% of plumbers won't have this document].
Today I am wearing my birthday badge:
Dear Mr Judge,
Today I am wearing my birthday badge:View attachment 75661
I like that. 😂
And actually, theres a clause regarding gdpr and whether you are in breach, if its justifiable and with good cause ( as in so a delivery company can deliver goods to a customer ) there is no breach...
Dear Mr Judge,
And l can request that through trading standards?
And in the meantime, do l have to reply to every email they send? Its nearly daily....
Yes or ask there advise and make sure you log when you phoned etc
IME, Small Claims Court judges don't look kindly on claimants who've declined a reasonable settlement offer and are trying to use the procedure to bully the other party.
Reply to What are my responsibilities? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
