Discuss Weird HW problem in the Central Heating Forum area at PlumbersForums.net
Hi guys.
-Small flat with a kitchen and one bathroom.
-Vokera Unica 32 BHE boiler.
Problem: Kitchen tap has low HW pressure and sporadic hot temp
  • It's sporadic so sometimes water comes out piping hot, other times the boiler won't fire
  • Diverter motor and valve checked and ok
  • Bathroom sink tea and bath has HW whenever tap opens.
  • Kitchen tap is one metre from boiler, bathroom is three metres from the boiler.
  • Doesn't seem to matter if CH is firing or not. CH works absolutely fine.
  • adding: Changed kitchen tap, worked fine for 15mins then back to sporadic running cold
I am thinking about changing the Plate Heat Exchanger.
But when it does fire the temp is excellent. Bathroom HW flow and temp are good though.
The bathroom HW does not point to the Plate HE.
So pretty confused here, any thoughts appreciated.
Change the kitchen tap but have a look at the flexis if it has them kinked ?
If you open the bathroom hot sink tap while kitchen hot tap has low flow/temp is the bathroom tap flow/temp ok and does the kitchen tap still have low flow but hot water?.
As suggested, maybe flexi kinked/damaged so swap hot/cold if cold flow was ok.
I'd be unlucky to have had a kink on old tap and new one but it is possible... Will check that...
So maybe not the plate HE? Shower is running hot so if it was the plate HE, I'd have consistently low flow, low temps... Is this right?
If so, then pipework as you guys say... Maybe the ballofix under the kitchen tap? Do they ever go wrong? I've never had one go wrong, anyone else?
I'm wondering about debris ? Like just before the ballofix. Suppose I could whip it off and check.. But the boiler has several filters for the HW...
Reply to Weird HW problem in the Central Heating Forum area at PlumbersForums.net
Hi all, thanks for adding me. My Veissmann v50 combi gas boiler has recently started to supply only lukewarm water to the bathroom above it. This...
Hi All, Hope somebody can help :) I have a vented HW system with a pressurised Ch system but got bit of a annoying issue, when the hot water...
Hi All Bit of an urgent one being that time of year and can't get a plumber out until after xmas even on an emergency callout I have just...
Hi everyone, Just a query about what size in KW gas combi boiler do I need for a top floor flat (3rd floor). I have a Vokera Easi heat plus...
1K
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for...
