Discuss Water usage very high when went on holidays in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys I am Rob and new on this forum, hope someone can shed some light on my very strange issue. Thanks in advance to all the replies.
I seem to us around 6 to 7 cubic meters per month. But in October that doubled to nearly 16 cubic meters.
The funny thing is I went on holidays from the 6th to the 20th of October, so was not even using water. So very confused.
I don't have any outside tap, and I don't think my neighbours robbed it.
So still trying to figure out what happened. It was back to 6 and 7 cubic meters for Nov and Dec.
So if had a leak outside of house and no one has fixed it then it should be still high.
We did not leave any taps on.
The only thing I did different was
I turned off the hot and cold valves in the Hot press and emptied out the two toilets and ran the taps till empty.
I did not turn off the mains water.
So is it possible that maybe the cold water storage tank in the attic was overflowing over the two weeks and hence why all this water usage.
No leaks in house or any stains on any roofs.
Why would turning of the valves cause the cold water storage tank to do this or is it something else?
Thanks in Advance for all the comments
Aliens searching for water Rob? lol
Haven`t got a clue bud but welcome to the forum all the same.
do you have an internal meter or external (in a pit)
Hi Rob. Guess you are from Northern Ireland?
Your overflow on cold tank could be running water when you are away. No water will be drawn from the tank, so the ballvalve if slightly faulty could be passing water. Very common while people go on holiday.
Thats sounds more like it. You are probably right. The tank was the only thing that could be leaking out the drain pipe. So the ball valve might be the issue. So would it be cause I turned off the water in the hot press? Because does not seem to drip any water all day when not using water in house.
Reply to Water usage very high when went on holidays in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Looking for some advice on my little bathroom project. I took the bath out. I got a shower jacuzzi thing. The base has 2 wheels in the...
