Discuss Water pressures in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dave1
Having a bit of a moment understanding reading water pressures dynamic and standing. I've looked at a system and the standing pressure was around 2 bar and dynamic with kitchen sink running about 0.25-.05 bar.
So when a combi requires a minimum 1 bar pressure is this asking for dynamic? My worry was I wouldn't be able to fill the heating circuit sufficiently, or am I just getting mixed up?
2 bar standing will fill the system ok.
Thanks Simon, I had a flow rate of around 13l per min, in your opinion would the pressures and flow rates that I've given be suitable for a combi boiler? I would have thought that the flow rate was on the low side and if two outlets were used it would result in poor performance at the taps?
I always thought with gas combis you were around the 9, 10 or 11 litre mark. We have a gas combi with decent cold water pressure and flow and it still doesnt like two hot taps open.
To be honest my main concern was the low dynamic pressure on the system and what affects that may have?
13l per min is fairly low now, dont be wacking in a 40kw combi or the water might be rather hot
I wouldn't be looking to fit a combi with that kind of pressure and flow. You will be better off with stored water and use a pump if they want more pressure for the shower etc.
@13lpm i wouldnt go much above a 24 or 28kw unless you can improve the flow
Reply to Water pressures in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the...
