Discuss Water leakage under the Kitchen sink in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
faserue
I have water leakage under the kitchen sink where I have a trap. If water is flowing freely and not rushing this is OK, but if their is a sudden rush of water it leaks out from the top of the trap which has a vent in it. How do I fix this ?
Do you mean it's coming from your unused washing machine connector?
as Chris says , its probably a unused appliance drain connector, however it could be a anti-vac valve that's broken/damaged if it is, you will have to replace all the trap. A picture will get you an answer.
Reply to Water leakage under the Kitchen sink in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks...
Sonya K
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
