Discuss Water Leakage Problem From My Upstairs Neighbor? in the USA area at PlumbersForums.net
Water is leaking from my upstairs neighbor into my house. He claims that the water leak was not caused by him. I called a master from site for water leak detection. But he could not enter my neighbor's house for detection. What do I have to do in this situation?
Contact the building owner
Usually there is a management agent for these type of properties you need to contact them for a emergency service call to inspect the property above yours , regards kop
Reply to Water Leakage Problem From My Upstairs Neighbor? in the USA area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
