Discuss Water leak outside my house in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
leah1234
I have just found a water leak on the outside of my side entrance to my house, we dag 4 ft down, this is lead pipe, what bits would i need to sort problem out, or would i need thames water to sort it. can i use lead loc sort this leak out?
Hi Thames water may have a lead pipe renewal policy? Is you have ago? There are S/Steel and rubber clamps available that can be used if the leak is on a straight bit of pipe.
Hi thanks for reply is s/steel stainless steel?
Yes its on a striaght bit of pipe, would i have to go to a plumbers shop? to get bits
I would have to sort the problem out meself if i can , i,m still digging , Thames water will be my last result.
Any suggestion is great Thanks
Philmac do a fitting for this purpose, much better than a lead loc under ground, WHPES on here got me on to them.
whats wrong with thames water, like most suppliers they want to save water and if they are similar to SWW they do one off repairsat no charge for customers.
Google onto water suppliers website and have look at their lead pipe renewal policy.
Where I am, they do a free connection if you run in a new main. But you have to replace your own service pipe. If its just a repair you want, as said Philmac do a sort of universal coupler.
So all you do, is cut the lead and splice in a piece of MDPE. Its favourite of course to renew an old lead main right from the water boards stopcock into the house all in one piece.
If you hunt around you will find a guide to the water regs that will advise you properly.
Reply to Water leak outside my house in the Plumbing Jobs | The Job-board area at PlumbersForums.net
