Discuss Water leak on Baxi Solo 2 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
pezza37
Please can you help. Currently have a problem with water dripping out of my Baxi Solo 2 gas boiler. Isolated elect & gas supplies. Took main shroud off and unclipped front cover of boiler. Checked main water pipes into boiler and sound , however small puddle of water has collected at bottom. Has anyone got any ideas of where it could be leaking from and possible solution?:confused: Many Thanks
water getting in flue is best senario heat exchanger cracked is worst scenario
can you see where its coming from?probably leaks worse when hot
Reply to Water leak on Baxi Solo 2 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and...
losing pressure
L
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the...
Firstly I won't be touching or going anything... I only want advice if this is right.. my partners dad has a aga that is solid fuel unregulated...
Hello everyone, Baxi Ecoblue System boiler which was recently serviced just before Christmas. There has since been a constant but slow drip...
