Discuss Waste toilet pan outlet position in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
Gk25
Can anyone advise? I have a new toilet pan plumbed and ready to fit but the pan waste is lower than the waste outlet in the wall. I have tried using a very good quality flexible connection out but I am still getting a drip at the pan end. Under severe domestic pressure to complete. Urgent help required. What can I do apart from lowering the outlet at the wall as I have already tiled this wall.
Gk25
welcome to the forum GK.
common for newer wc waste outlet to be lower than the existing.
lowering the pipe through the wall is really the way to go,
you could raise the wc?? might look rubbish??
Welcome to the forum. Two options, lift the pan or lower the waste! :nono: only goes downhill .
you could put a ring of silicone around the pan spigot then slide the connector on then leave for 24hours that will solve the drip.
lower the soil pipe once and for all.
or fit one of these using method one
mcalpine offsetView attachment 18261
Oh the number of times you come across these and the custard cant fathom why it wont flush properly :)
Thanks guys for all comments. As a non plumber, I didn't want to hear about dropping the waste in the main stack. But it was the only solution. It is now done, I have learned how to do something different. Happy days all round. I ' m stiff and sore, up and down stairs and ladders but worth it.
Was told this second day on site pay day Friday and :nono: don't run up hill
Reply to Waste toilet pan outlet position in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A few years ago I installed a wall hung toilet pan in my last house which did not flush well when disposing of waste solids. The water would rise...
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled...
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the...
Hiya - posting in this forum as I'm guessing this relates to my neighbour above's boiler, but I may be wrong so please say if so. Basically the...
I currently have a floor standing pan in a downstairs cloakroom. The waste is vertical about 10mm on the inside of a 2- brick external wall. As...
2K
