Discuss waste pipe smaller than toilet trap in the USA area at PlumbersForums.net
Im fitting a new toilet but my waste pipe in the wall is smaller than extendable trap behind toilet! so it doesn't fit inside the external waste pipe. What can I do?
Can you tell us what size the pipe is and post a photograph from around 3-4ft away.
You could load a photo as rpm suggested, but It’s probably a 3 or 3 and 1/2” connection, a multikwik or McAlpine connector should dirt your problem. MKS3 or MKS10 for the multikwik’s. You could measure the size of it to confirm.
Here is the soil pipe and pan connector - both 4 inches diameter
Daft question, but have you already got a pan connector?
Yes it didnt fit. Do you think this would work
It should do if the 4" one doesn't. As long as it's a tight fit.
Reply to waste pipe smaller than toilet trap in the USA area at PlumbersForums.net
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built...
    • Useful
My parents have a leak from kitchen sink. My dad removed waste trap and since refitted it leaks, but there wasn’t any kind of seal on it, I got a...
Hello hello,, Hoping there are some experts or experienced Bulgarian plumbing chaps in this site ?. Here in the UK I can fit a bathroom just with...
Hi all, grateful for your expertise on the following. DIYer, not pro. Rural property in France Single storey. Septic tank. Late 80s construction...
Hi I need to this cast iron pipe back as my new back to wall toilet won’t fit otherwise. Cutting it back i am going to lose the collar. So what...
