Discuss Wall hung basin pulling away from wall in the USA area at PlumbersForums.net
I went in to fit a small wall hung basin today and had a devil of a job trying to keep it tight to the wall along the top edge. I’ve done a couple of wall hung basins before but never had one where the fixing points were right at the bottom. It was supplied with 2 wall anchors which I installed but even tightened the top edge was pulling away and the adhesive wasn’t strong enough to keep it in place. I was worried that tightening any further would crack the ceramic. Is this a common design? And if it is how to you deal with it? It seems baffling to me that anyone would design a sink this way.
Yes common issue normally just pinch the bottom fixings and glue the one or two faces that are on the wall
I sandwiched mine with 2mm neoprene to avoid point loading then ran down the top edge with a silicon beading tool.
Pays to use quality fixings and throw the supplied ones. No point spoiling the job with them.
Reply to Wall hung basin pulling away from wall in the USA area at PlumbersForums.net
  • Sticky
