Discuss Vokera sabre he29 hot water fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Piperdave22
hello! Tried to post this in the gas safe part but it wouldn’t let me for some reason.
I’m gas safe registered
Has anyone worked on these Vokera sabre 29he combi boilers? I have one that when you run the hot tap it clicks loudly at pcb area and goes cold then hot .
Initial thoughts are a blocked heatplate but it looks like I have to take everything apart just to take it off and check it!
Also suspecting divertor valve or water turbine can anyone point me in the right direction?
Central heating is working fine with no probs
You need to send your gas safe number to admin before you can post in the gas safe only area.
Have filled in the section with my gs number on profile when signed up so may just need to be approved thanks anyway!
Yep! We manually check so no one's in there that shouldn't be. Safety first!
Debris in the plate is favourite bud you often get a ticking noise and the burner drops in and out often worse when runnning a bath tap. Kop
Reply to Vokera sabre he29 hot water fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
