Discuss Vokera Compact leaking heating cock in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys. My Vokera Compact started leaking today from both heating cocks. It's just a slow drip so far. They do stop leaking if the heating is turned on but as soon as it cools down they start to drip again. I find it strange how they both started to leak at the same time. I have attached a photo of the heating cocks. I have priced new heating cocks up and was wondering if I could fit the replacements myself or can these be fixed ? We are very low on cash flow at the minute as we have just bought the house. I have done quite a bit of plumbing in the past so I'm sure I could easily replace the heating cocks but where do I stand legally on this? Any help would be very much appreciate. Thanks in advance. Kody.
you sure the leak isnt coming from higher up (rusting on the case) in this case if it is best seek / get a gas safe engy out
have they been shut recently ?
two options how good are you at draining your heating?
two options
replace the valves like youve said
or strip the valves and replace the orings
one to ten scale (1 being easy etc)
4-5
Are the orings easy to get hold of ?
That's the unknown screwfix do an oring kit there should be something in there
And legally?
You mean gas safe wise ?
Yes. I mean do I have to be qualified in any way to replace these parts?
No as there outside the boiler
Unless your in rented accommodation?
I would definitely buy the isolation valves before taking them off or touching them . Yoou should be able to get them from a gas parts merchants , of the likes of the plumb center
Reply to Vokera Compact leaking heating cock in the Plumbing Jobs | The Job-board area at PlumbersForums.net
