Discuss Vokera Compact 25 ignition failure (can anyone help a rookie) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
clemda1
Hi Guys New to the boiler diagnostics, so go easy
http://www.vokera.co.uk/wp-content/uploads/2014/02/Compact_A_User_and_Install_Manual-v1.pdf
Carried out initial electrical safety test.. Earth resistance, Resistance to earth, Short circuit and polarity all ok.
Put a hot water demand on the boiler, pump and fan engage, ignition sequence starts and the boiler fires and lights Fan speed then increases for about 5 seconds then boiler locks out and LEDs goes to solid amber and red
My first thought was flame rectification electrode. Tested with multimeter at the board and it was ok.Called volkera and they suggested it was the PCB as no further ignition attempt were made (should try and relight 5 times)
Given i'm a rookie before i get the customer to fork out £150 for a new PCB.. Just wanted to get a second opinion...
Sorry. Not in open forum.
Build your post count up to 10 + then send a message to [email protected] with an image of the front and back of your gsr card.
Then you can get all the help you need in the private forum.
Reply to Vokera Compact 25 ignition failure (can anyone help a rookie) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
