M
Discuss Vitra dual flush running constantly....Help? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I think you will find it will be the seating washer on the flush section being gunked up
not sure if your one will allow but most twist about a quarter turn and lift out to expose seating washer for you to check/clean ....water will continue to fill as level cannot be reached untill you stop water passing by the seating washer hope this helps regards turnpin
better doing what turnpin says, flush valve is passing, you may need a new one, probs nothing wrong with your float valve.would of advised that but the valve is one of them crappy ones you get with b and q toilets, better doing what I said and get the best one on the market no more problems
Mr M, Turpin,
Is the seating valve on the other component?
I had to but the same ball valve mech that is fitted, short on time & work o'sees.
Will fit tomorrow & see
Cheers, for all the input guys, hopefully have a dribble free new year ;-)
Mick
No mate, the tube in the original picture I presume is the overflow into the bowl?
Have taken the flush mech out now, is a bead of silicone a good idea or not?
Can't see any mate, gonna let it dry out completely then see.
Will silicone do the trick or not?
Was looking at putting a layer all around the area then fitting the valve stack.
Mick
did you replace with complete new unit or take out and replace?:banghead: OK, what can it be?
I've replaced this complete unit & it's still running into the pan!!!
The area on the base of the cistern seems damage free & clean. Help!!!!
my thinking was the flush valve, if not dirt, some develop air bubbles and constantly dribbleI think you will find it will be the seating washer on the flush section being gunked up
regards turnpin
Glad you found a soloution to your problem and again thanks for letting us know regards turnpinWell,
Could not find plumbers gold, so bought some Evo Stick "sticks like sh*t"
Put a bead around the hole & screwed the flush assy in & it seems to have dome the trick!
Thanks for all the advice on here
Regards,
Mick
Reply to Vitra dual flush running constantly....Help? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
