Discuss Vinyl to tile drainage issue in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi
Floor in wet room is changing from vinyl flooring to tiles, floor will rise by about 13mm (tile and adhesive). The current drainage is 110mm for vinyl floor, what can I connect to current system so will be level with tiles. Wet room is on ground floor over concrete. Pls see photos
Thanks for reply. above won't work for , I need to have an adapter to "push" fit into the 110mm drain pipe and square tile shape grid so will be level with tiles fitted.
Reply to Vinyl to tile drainage issue in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
