Discuss Victorian terraced drains persistently blocked in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. We are having persistent problems with our drains blocking and hoping that someone here can provide some advice and solutions.
We bought a Victorian terraced house two years ago and the main drain at the back, under and at the front of the house have been consistently blocked since then.
The problem:
Lifting the drain cover at the front of the house shows that the waste is not flowing through the trap sufficiently and it is blocking as a result.
At the back of the house, the waste does not flow enough under the house and backs up very quickly, giving us an overflowing drain cover and terrible smells in the kitchen.
Each time the drains are unblocked, they are blocked and stinking again in a couple of months.
What we have tried:
We have had the drains un-blocked (rodded and power-washed) several times.
We have had the drain under the house de-scaled twice.
We have had CCTV down there twice and it has shown no bellies, lips or other blockages in the pipes… just a bit of build-up of scale.
We had someone put some pretty strong chemicals down the trap that connects us to the main sewer to clean that out too.
We have been told by a couple of indy drain companies now that this is a persistent problem that won’t go away.
Essentially, because we don’t have enough water going down the drain (low-flow toilets, no baths, etc) and because the drop in the drain under the house is very shallow – we will forever have waste water that does not flow enough; scale builds up; becomes more blocked; more scale, etc…
Really grateful if anyone can advise?
- Does this sound right?
- Are there any solutions to the persistent blockages?
- Any solutions to the low-flow or shallow drop in the drain?
Thanks in advance.
I am interested in your problem. And will ask you pertinent
questions. 1st
1. location post code wil do
2. can you put up a ground plan ..sketch plan
3. Are you owner occupier leaseholder or a renter ?
Centralheatking
Has anyone mentioned an Interceptor on the outlet to the front
manhole?
https:///www.labc.co.uk/news/my-dad-told-me-about-them-drain-interceptors
manhole?
Hi - Thanks for your reply.
Yes, should ave mentioned that we have an interceptor trap at the front of the house where we connect to the main sewer. This has also been chemically cleaned out recently.
Problem still persists.
Any suggestions welcome.
Thanks.
Yes, get rid of the trap.
Unfortunately not a cheap or easy job.
There's no need for them in todays vented systems.
In a system with poor flow due to inadequate fall on the pipework the trap will allow grease to settle in the trap and eventually block.
The alternative that I used to do in one of my previous houses and my Son used to do in a house he owned later was to tip 1/2 a dustbin full of water down the manhole regularly to move solids from the trap.
Thanks. A neighbor in the same terraced row suggested removing the trap when we moved in, but everyone we have had out to look at the problem (including Thames Water and 3 indy companies) has advised against it or just said it is a job they wouldnt do themselves.
How big of a job is it? In the £,000s?
Go on Thames water website and get an approved underground drainage contractor to quote. Yes in the thousands but how many depends on the ease of digging so not possible to say without a site visit. Balance that against the cost of getting someone out on a regular basis to clear it and the unpleasantness of the problem when it blocks. Also try your insurer.
Many thanks. Will check that out.
Reply to Victorian terraced drains persistently blocked in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
B
    • Friendly
Hi, I've followed this excellent forum for several years but have never posted, so decided I'd better give some details. My status is the upper...
