Discuss Vent valve height in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
Unregistered
Looking at replacing a normal radiator with a modem taller vertical type in my son's bedroom. As top of new radiator will be higher than the system vent and pump, will this cause a problem? Or do I need to extend vent pipe to be highest point?
No as V/radiator will be highest point just fit a rad auto air vent , replaces normal air vent about Ā£5.
Please register with us and start a new thread to receive additional answers to your question.
Reply to Vent valve height in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
