Discuss Veissman ,Ideal vogue or Bali Platinum in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Cowheat
Hi,would like some advice on which boiler to install.I have had 3 quotes for a Ideal Vogue,a Veissman Vitoden 100 and a Baxi Platinum 33kw.Any advice would be greatly appreciated as I am wanting to install soon.
As above all down to price wise
I'm a fan of the Viessmann
The quotes I have had are Viessman 100 £1600,Ideal Vogue £1590 and Baxi platinum £1750 and Ideal logic+ £1390.Do any of them have any faults I should know.
All good in their own right decent warranty on them all to up to you really
From the same installer?
What else is included - filter, flush etc?
They are all from different installers but I have had quite a few out to give quotes and they all say Baxi have it all sewn up in the northeast where I am and not many will give Ideal the time of day but I really think the Vogue could be a good system.
Sorry forgot to mention they all include filters ,magnaclean or fernox sentinel condensate and controls.
How many quotes?
Are you looking for the cheapest?
How many quotes?
No just want to make sure I get the best boiler at the right price.Ive had two quotes for the Ideal Vogue and there was 800 between them.Dont want my eyes taking out.
I was a big fan of Ideal - Vogue as the premier option, Logic + as a mid-price. Gone off them due to their approach to warranty work... Finding non-existent faults to try and get out of warranty. I haven't fitted one for over a year now..
I fit loads of platinums never have any problems there warranty back up is ok too
10 years warranty on a Baxi platinum fitted alot of them and they work well a little bit older technology but tried and tested and no plastic components, viessmann I have done the training at their factory which was impressive and I have just quoted on my first install for a 222-f storage boiler so can't coment yet , ideal I am a member of connect and loved the mk1 logic plus+ which was great for the older generation with its digital read out telling the customer what mode the boiler was in with a 7 year warranty , but the recent mk2 which I fitted last week now has a horrible white plastic front case which will yellow and look shabby and go brittle in no time the vogue looks like a valliant eco tec plus inside so nice bit of kit but again looks like alot of plastic in the case in all honesty I am not fitting them anymore , have a look at worcester bosch 34cdi classic again tried and tested fitted one last week great boiler super quiet 5 year warranty plus 1 year extra for their new filter and another year for their controls I fitted the wave smart control so 7 years warranty and back up is good but will cost £2000+good luck with your choice regards k
Not being funny but a couple of the quotes seemed on the cheap side to me , looks a council bash fix it to the wall rads get hot YES , water gets hot YES now gimme your money and see you later .
However i would go with the baxi as its tried and tested , ideal no back up wriggle out of warranty . The veissman's i have seen have been in tatters .
The Baxis are coming in at 1800,the Viessman and the Vogue are about the same at 1600 although I did have a quote for 2450 for the vogue..Still cant make my mind up.
What are you replacing?
Is it a combi boiler if the same size?
I'm replacing a Vaillant turbomax 824 24 kw , its 13 year old.Im looking to go to 28 or 33kw.
Have any mentioned upgrading the gas supply
The new boiler will also be condensing and will require a connection to drain
Yeh they have all mentioned about changing the gas pipe to 22 mill and drain for the condensate.
Depending on the length of the gas pipework to the appliance you may need 28mm , something dont seem right as said before seems cheap hope all goes well though
which boiler would you install king of pipes..Do yo think the Veissman Vitodon 100 is better than the Ideal Logic+ and Vogue or vice versa.
Viessman bud get a registered installer and you will get 10 years warranty , or get the Baxi platinum also 10years warranty no brainer really no worries for 10 years other than a service each year ,sorry to say gone off the ideals after the update the casing is awfull cheers k
^^^^ you have to pay £100 extra 5 years on top of the first 5 years, still a bargain
ive read a lot of bad comments about the Viessman Vitodons 100 is it a newer model that's out now where the problems have been sorted out.Said they were prone too leaks with the rubber hoses.
If your worried go Baxi platinum its all about how it's fitted bud the most important thing is having a clean system to start with , a good quality filter on the return to the boiler , inhibitor and a good warranty
Reply to Veissman ,Ideal vogue or Bali Platinum in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey folks, I'm wondering if someone could possibly help, I'm looking for a possible part number b4 I call ideal in the morning, I fitted an...
Deleted member 120897
Hello all Just gauging if there's any interest at all in this. I have an Ideal Vogue Gen2 S32 boiler. It's currently in use in my house since...
Hi everyone, I'm hoping to get some advice on an issue I'm having with my Vaillant Ecotec Pro 24 boiler (R1 PCB). It was installed in 2013 and has...
Another boiler suggestion post. 4 bed detached house built 20 years ago with cavity wall insulation and double glazing. 1 bathroom and separate...
4K
Hi everyone! Parents not used the boiler since 2013/2014, since installing a new wetroom for them they have now decided its worth getting the...
