Discuss Valiant vrt 230 replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi folks, I have to replace a Valliant vrt 230 stat/programmer. Can you advise a direct replacement/alternative for this discontinued item.
TIA
It’s for a rental property, so one which will provide similar functionality to the existing (and not need rewired!).
Cheers.
Reply to Valiant vrt 230 replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it...
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
PSxxxxxx
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
