Discuss Vaillant flue ... ... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
hello lads,
I just wanted to update anyone who is installing a longer flue outside.
I called Vaillant today to find out what kind of flue I could use for outside. They have told me twice I could use the standard flue which is rain resistant BUT ( couldn’t believe my ears ) when it comes to join to extensions together I need to use silicone and then put the clamp around. Once that’s done, I have to tighten the clamp and put from outside again silicone around to create a water tight seal :D
Sorry guys but that can be only done in uk haha haha
hello lads,
I have had this argument with them before. I think this is a stupid rule and I fit Vaillant’s. I AR them if there are corroding.
So what you going to do
I would think plastic would have been better like a plume kit. Perhaps it would be also not as great as you can pull them too easy apart.
Your not going to install the white flue externally are you ?
NO! I did say I will comp,y to r gas which means I will run the flue externally and will use the silly silicone as they told me. However, it’s not the right way in my opinion.
Reply to Vaillant flue ... ... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, Desperately in need of help. Getting very annoyed with myself Replaced the click plug in my bathroom for a new Basin Slotted one along...
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW...
Hi, I have just noticed a damp patch around where my boiler flue exits through to outside wall along with a rusty colour around the collar of the...
Good afternoon, I was hoping someone could advise regarding the regulations around flue terminations through a 'fake' window. We have a...
2K
Hello, We had an extension built seven years ago. Initially the builders' plumber connected the heating to the house system but this didn't work...
