Discuss Vaillant 837E pump compatibility in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jill
My Vaillant turbomax 837E combi has just begun to make a rattling/clunking noise when turning on hot water & heating. The pressure gauge dial flickers (it doesn't drop but just flickers up & down by about 1mm). Someone said the pump has probably gone - could this still be the case if I am still getting hot water & heating (tho' I daren't turn it on for long as the noise sounds pretty scary).
I've been looking for compatible pump on line - the part number is 59866527 & there's another number 161015 but I can't find this pump anywhere on the entire internet. Does anyone know if there is another compatible pump? I've been searching for hours! Any help would be greatly appreciated.
Jill
If pump back case OK just new head required,any plumber who works on these boilers,should be able to supply and fit head required,no problem :)
imho
get someone in to look at it ,could well be the pump but could be a fan as well both these components will make the boiler noisy
Thank you.
I will do - it's just finding someone reliable & honest in SW9 as every plumber I've had has ripped me off - ie with my last boiler I had practically every part replaced at 50 times it's RRP (by various plumbers within a month) only to be told two weeks after forking out £600 that I would need a new boiler instead of just telling me that at the start!
So I thought I'd try & get the part first, pump being the usual culprit. But maybe I should just put a post out on this site for an honest plumber I know they are out there somewhere!
The pump back case looks fine. Mark GS 124619 has suggested it could be the fan. I just need to find a good corgi plumber near SW9. Thank you to both of you for taking the time to reply. All the best.
Jill
what part of sw9
pump is easy enough to check resistance and flow...
have a part no for you
Thanks newbie1.
I'm in SW9 9DF. I have given my number to Puddle (administrator) who's kindly said he would forward it to you.
All the best.
Jill
Reply to Vaillant 837E pump compatibility in the Plumbing Jobs | The Job-board area at PlumbersForums.net
