- Messages
- 5,076
Discuss unvented water heater in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If the unit holds less than 15 ltrs then its not classed as an unvented unit so there is the stringent safety controls as temperature pressure relief valve, though it will have safety electrical cut outs. More than likely it may be able to expand to waste if its under 15 ltrs hence the reason its on the cold feed. I have never been involved with zip but im sure its a part of Heatrae Sadia.
TTB
TTB
Sorry ttb but beg to differ! Under 15 litres was not classed as coming under building regs but is still unvented and was under impression still 'must have' temperature relief valve fitted to vessel, not pipework even if under 15l. Doesn't matter unless it has an open vent of some kind. All unvented must have stat @ 60, cut-out @ 85 & temp relief valve @ 90. New building regs include all unvented heaters, even under 15 litres although do not have to notify bldg regs dept.If the unit holds less than 15 ltrs then its not classed as an unvented unit so there is the stringent safety controls as temperature pressure relief valve, though it will have safety electrical cut outs. More than likely it may be able to expand to waste if its under 15 ltrs hence the reason its on the cold feed. I have never been involved with zip but im sure its a part of Heatrae Sadia.
TTB
thermal stores now come under new part g building regs although not sure if they need to be notified or not
Yes, thermal stores are notifiable, under Part G. They are still classified as unvented, Only difference really, is the dirty water is on the outside of the coil. Reason being the thermal store is almost certainly going to be on a sealed system.
I have to disagree there as most thermalstores are open vented supplied by a seperate F&E tank or a combined F&E tank, other point is if they are unvented where does the temperature relief valve and the expansion valve go.
TTB
Most new systems are sealed, Expansion vessel, pressure relief valve. overheat stat on boiler, controlled pressure, discharge pipe. Whats the difference on the concept to an domestic hot water unvented system? Your heating up large volume of water in a sealed enviroment, same devices required.I have to disagree there as most thermalstores are open vented supplied by a seperate F&E tank or a combined F&E tank, other point is if they are unvented where does the temperature relief valve and the expansion valve go.
TTB
Reply to unvented water heater in the Plumbing Jobs | The Job-board area at PlumbersForums.net
