Discuss Unusual Viessmann 111w problem in the Central Heating Forum area at PlumbersForums.net
I have a problem with Viessmann 111w
I have a Vicare sensor and app.
It goes like this :
If I have a boiler in DHW only everything works as it should, but then I switch it to DHW and heating. Temperature in a room is 21 degrees. I set the boiler to come on when the temperature is 17 degrees.
Every time I run a hot water, boiler comes on, fills a hot water tank, and as soon as it switches off, it dumps a lot of hot water into the radiators. Every time.
I put my baby to bed at 7pm (and my heating is on from 7) and I still have a shower, do washing up, wash my hands etc. Every time it dumps hot water to the radiors. By 10-11pm when I go to bed , temperature in the bedroom is 25-26degrees!
I had Viessmann engineer coming 4 times, he can't figure out what's wrong. Now they start telling me it's normal, that it has to dump that water to radiators. Surely that's not normal. My bedroom gets hotter every time even I don't want it to. And it doesn't dump any hot water when only in DHW mode.
Anyone might know what's going on? I'm not wrong it's not normal, am I?
Anyone's got the same boiler and could check for me what does your boiler do?
I would really appreciate any help.
Jakub
You have a HW cylinder, not a Combi boiler??, if so can you see if you have one motorized valve with 3 pipes or a number of motorized valves with 2 pipes.
I believe it's one valve with three pipes. They changed it today. Behaves the same. Opens for a few minutes and circulates the water. They changed motherboard/programmer and still the same. Bypass too.
OK, its a stored Combi Boiler.
If there's no demand for CH and the HW store is being heated the rads certainly should not be heating, is this happening?. If the CH is on, and its programmed off or a roomstat if installed, switches off the boiler then the circ pump should run (overrun) for a few minutes but rads should then cool down until next the next call for CH.
If the CH is off and you are not running a hot tap or whatever then the boiler may fire up occasionally to keep the stored HW up to temperature but the rads should not heat up, you will have to pester them (or keep pestering) until its sorted out,
I remember reading somewhere about someone who had the same problem with a Viessmann 200-W apparently cured I think by replacing the bypass cartridge although someone else stated that if "continuous heating" is selected that the CH will heat as well except that there are zone valves to prevent this happening, thats the way I interpreted it anyway.
Nope. (CH off)
Yes. CH is on but thermostat is set to, say, 3degrees so keep CH from firing. I use hot water. HW store is being heated, rads still cold. As soon as the boiler stops heating the HW store it dumps hot water into rads and circulates for some time.
And it happens every time I use hot water. I wash my hands, another rush of hot water into rads. My wife washes her hands - another, I do washing up - another, etc. When we had guests rads were properly hot as there's always someone using water. Surely it isn't normal , is it?
I only use radiators in two bedrooms as I have a wood stove downstairs. And I only want it for the night in case temperature drops outside (and thus inside). Surely that's what thermostat is for (especially wireless one you can take to the bedroom)? Someone told me I should have all rads open but what's the point in that ? I don't want to heat whole house all night, why would I?
Sorry if it looks like I'm ranting, I'm not I'm just really confused by all this. (And especially not having a go at you, just frustrated , sorry)
Especially why does it apparently have to dump the water when heating is on (even if thermostat keeps it off) but it doesn't have to do it when heating off, when it does exactly the same thing, which is heating hot water ? 🤯
Reply to Unusual Viessmann 111w problem in the Central Heating Forum area at PlumbersForums.net
Hi, I have a problem with Viessmann 111w I have a Vicare sensor and app. It goes like this : If I have a boiler in DHW only everything works as...
hello! while saving up for a new plumbing and heating installation for my new one bedroom flat, i did a lot of research on different boilers and...
2 3 4 5 6
4K
  • Locked
Hello, I have a ferroli falcon 2 boiler (yes it is pretty old). A few days ago the hot water started going hot and cold when running. Monitoring...
I am having a problem with my main 24he boiler where the flame is constantly clicking on and off with the heating and when using hot water. Some...
I have a Viessmann Vitodens 222-F FS2B 26kW Storage Gas Boiler installed in 2014. The boiler has developed a problem recently where it short...
2K
tinodj
T
