Discuss Underfloor heating - manifold valve leak in the USA Plumbers Advice area at PlumbersForums.net
My underfloor heating has sprung a leak where one of the pipes reaches the manifold. I have tried giving it a bit of a clean and tightening it, but to no avail. Every time I re-pressurise the system is goes again.
Is it as simple as shutting off the water supply to the heating and replacing the valve myself? I'm fairly happy doing most DIY, I just don't have that much experience with plumbing.
I have attached an image showing the valve where the leak originates. I can't see any issue with the pipe itself and so am assuming it is the seal in the valve?
Any thoughts much appreciated
Where’s it leaking from the top brass nut or the plastic nut
Reply to Underfloor heating - manifold valve leak in the USA Plumbers Advice area at PlumbersForums.net
