Discuss underfloor heating guides in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jase158
Hi all,
I have secure the underfloor heating job, arranged a plumber who knows his stuff to give me a hand setting it up,
But just want some advice
Boiler is downstairs, pump in boiler, airing cupboard upstairs with 3 port valve and cylinder, manifold will be below boiler.
1. Where is the best place to connect flow and return, given that it has a 2 port valve, could i just connect the flow and return into the boiler flow and return or should it be after the 3 port valve?
2. How high is the insulation on the edges?
Just a little backround, underfloor heating is having 70mm insulation and 70mm screed.
Thanks again, will ask plumber that I am working with but I am really busy this week and want to work out costs.
Underfloor needs its own pump after mixing valve and teed in to return
Any chance of changing the system to S Plan?
A three channel programmer would give you, hot water, radiators and underfloor as all should be controlled by thermostats.
UFH manifolds usually have their own pump and mixing valve so the S plan might help to make the controls easier to manage.
Just thinking out loud.
And liquid screed is better for underfloor quicker reaction times
Thinking correct
The f&R can be connected off the boiler as it has its own two port to control it.
the perimeter insulation is 150mm high
Reply to underfloor heating guides in the Plumbing Jobs | The Job-board area at PlumbersForums.net
