Discuss Unable to adjust co2 readings vaillant boiler in the Gas Engineers Forum area at PlumbersForums.net
Unable to adjust co2 readings on a a vaillant ecotec boiler it’s an lpg model I’m currently getting 0.0004 ratio, can’t get a higher co2 percentage than 8.6% (minimum being 9.7 without cover) and the ppm is around 40
Have tried new gas valve new Venturi and new pcb. I’ve cleaned burner and condensate pot and checked flue integrity which is coming back spot on the gas inlet supply is correct aswell
Have called technical help at vaillant but they are about as much use as a chocolate teapot
What’s the temp of the flow and return ?
Reply to Unable to adjust co2 readings vaillant boiler in the Gas Engineers Forum area at PlumbersForums.net
