- Messages
- 34,363
- Solutions
- 2
thing is the appliance in question is the gas meter so your turning off the gas meter ?
Discuss Un-sleeved gas pipe, landlord saftey check. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I get that. And I know what you are saying. But it doesn’t say cap off.thing is the appliance in question is the gas meter so your turning off the gas meter ?
Yes. But one is capped (ID) or isolated (AR)the effect is the same tho a customer with no gas
The point about the meter box is the point I was making and the reason I was asking which gas pipe. But thanks for the support.The main point here is the fact of the location, because it's in meter box there is unregulated gas pressure (up to 75mb) which could potentially have a much higher leakage rate. Also no dilution with air will take place in a meter box. The key point is that prevention should be in place to stop that entering the building in the result of a leak. Ie the sealing in this instance is more important than the sleeve providing no deteriation of pipework.
As it stands its AR and turn off. Sealing it would lead it to be non compliant and advise customer regarding sleeve.
If it wasn't in a meter box it would just be non compliant regardless of sleeve or seal.
Hope this helps!
If owner disagrees with AR turning off, do I need to fill out a form and attach a label and what should I do then if they don’t let me turning the appliance off when having AR ?Nah, ID capped , AR turned off , with the owners permission of course .
But you still have to leave a notice and it is still AR?Just to chuck another spanner in the works , I did my ACS last week and couldn't believe what the assessor was saying . this is new ish , I didnt know.
Only for certain AR’s , if whatever you are AR-ing doesn't actually remove the risk , you can leave the appliance on !!!! Its in the new niceic books .
If that’s the case mate. It definitely doesn’t happen often. You are one of the first people I would come to for advice as I know that you have a wealth of experience and knowledge (a heck of a lot more than me) the reason I was pushing so much was it is what I had drummed into me for years when I was on the cards. I panicked for a second that I had been doing it wrong all this time. But the rules are constantly changing so we are all wrong at some point.Sorry I was wrong for once
I don't quite understand... Surely everything your at risking...by isolating the appliance it's going to remove the risk or am I being thick?
It’s called ‘AR no action’ and the best example I can give you is a built over PE service. Dropping the handle will not in any way reduce the risk as it’s upstream of the ECV, however the situation is still ARNo your not , I thought exactly the same thing when I heard it , as we went through the re-assessment they would ask AR , turn off ? leave on ? . No joke this
Eg ( copied out off book ) no AECV at point of entry into a building where one is required, that is AR but its AR “leave on”
Reply to Un-sleeved gas pipe, landlord saftey check. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
