Discuss U/floor heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
southcoastboile
Just brought a property and I was thinking of putting underfloor heating on.
we don't normally get involved in it.
i have a combi boiler and I'm renewing the kitchen also. If it were to be done it would have to go on top of a solid floor.
currently there are radiators throughout.
just wondering if anyone can recommend a decent system. I would rather spend a bit more and get a good system that works well.
if anyone can recommend a system to suit I can take a look and make up my mind.
thanks !
You can get 'off the shelf' quote for the design and materials from:
The design is critical:
The Underfloor Warehouse (now flogas renewables)
Nu-heat
I think Speedfit will do you a design as well.
We use emmeti (pex/al/pex pipe)
To go on top of an existing solid floor, you need to insulate first then pipework in screed so you need ideally 150mm ... anything else is a compromise.
Or you can use liquid screed it's suited to underfloor heating better in most cases
Thanks for that. So what would you say the best make and design I could go for Worcester?
Reply to U/floor heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, gotta a bit of an issue with refilling my underfloor heating. Am I right in saying that the flow meters along the manifold should be on the...
I'm attending a wet underfloor heating system, it's an old one ..No flow meters, just adjustable valves on the returns with conventional...
Hi there, I'm considering having my heating system controlled by Honeywell Evohome. I have a question about the underfloor heating controller...
I am starting a large victorian renovation and it will involve, (amongst everything else) installation of an entirely new heating and plumbing...
