Discuss Two toilets backflow problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sparkspark
I've got two toilets installed back to back either side of a stud wall, they are joined with a branch, which then flows to the stack and vent. When the further toilet is flushed, it causes the trap level in the near toilet to drop by half inch whilst the other completes the emptying process. When flush complete, some dirty water siphons back to the near pan. I was thinking as the problem is neg pressure, could I install an aav from the boss connection on the branch, taking it up above the highest point in the pan via 40mm pipe.
Any ideas gratefully received :)
Thanks for the quick reply, I'll try and get one locally in Bristol Monday, cheers.
Reply to Two toilets backflow problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
