- Messages
- 5,439
1) Keep seeing plastic waste pipes on external walls which are curved. Is this achieved by heating and then bending by hand when run path can't be achieve by fittings alone...is this a difficult technique? I ask because been asked to change cracked high-level cistern which has lead flush pipe. It curves in funny way to pan and I imagine replacing with plastic, if need be, would be difficult to line up. Could it be done by heating plastic or is it really hard?
2) So..it turns out you can burn wood quite easily through your burn mat if held on long enough...i found out the other day. lucily mucking about in my shed... or did i get unlucky / use a rubbish mat?
