Discuss Trying to source 28mm washer in the DIY Plumbing Forum area at PlumbersForums.net
Hi
Im about to replace pump isolator valves on my grant boiler but the 28mm valves did not come with washers and I can seem to find them to buy. Can anyone please advise where I might be able to find them?
I did, maybe I'm getting confused over the size of the washers that are mainly stated in inches. I assume 28mm is the inner diameter of the washer? Would the following work?
https://www.NoLinkingToThis/p/arctic-products-fibre-central-heating-pump-washers-1-3-4-2-pack/4252j
Reply to Trying to source 28mm washer in the DIY Plumbing Forum area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
