Discuss Trv & lockshield valve change in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Muushy
Is there a wayin which i can take off exisiting Trvs and Lockshield Valves and put new ones in without draining down the system?
If you plug the cold feed and open vent, shut any auto air vents and shut off the valve at one end of the radiator you may be able to change the valve at the other end of the radiator. This won't work if there any minor leaks in the system.
Mike
Thanks Mike can i buy theses plugs for the tank? and what if its a sealed system what would you do then?
Regin do a kit for rad valve changing. With a sealed system as long as all aav's are shut you can release the pressure with the prv and then use the same technique.
Mike
Reply to Trv & lockshield valve change in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi all Noticed bad smell in my drain out side put my hand down and it unclogged it for now however I checked my sewer drain and after flushing my...
