i have all the e codes
E168 pcb failure
E133 - Flame Failure - possible causes
[*=1]No gas, payment meter ran out
[*=1]No spark
[*=1]Faulty spark/sensor leads/earth connection
[*=1]Faulty spark gen
[*=1]Spark gap to large (4mm)
[*=1]Flame sensor gap to large (7.5mm)
[*=1]Condensate frozen/blocked
[*=1]flue/heatexhchanger blocked/restricted
[*=1]flue seal fault, flame lift (visciation)
[*=1]Under gassed
[*=1]faulty gas valve
[*=1]Check resistance - 10kohms at 25[SUP]o[/SUP]C reducing with temp rise
E50 Flue Sensor fault
Check resistance - 20kohms at 25[SUP]o[/SUP]C
E110 SAFETY /HIGH LIMIT STAT OPERATED
E119 - Low Water Pressure Fault.
Top up pressure & . check for leaks
[*=1]check prv is it passing?
[*=1]put heating on and watch to see if there's a significant pressure rise. If so suspect expansion vessel has lost its charge.
[*=1]If unable to re-set then suspect blocked weep to pressure switch or faulty switch.
E125 primary circuit circulation fault
[*=1]Pump fault
[*=1]Flow restriction through heating system
[*=1]
E130 flue ntc activated
E160 fan or fan wiring fault
this on all mk1 platinum,duotec,gold,heatmax and promax combis
