G
Guest123
Try to tighten the tap nut slightly first before trying to slacken it off but watch you don't damage the bath. You can loosen stubborn screws this way too. If it's a basin wrench, put a longer bar or a long strong screwdriver on the end you are holding to use as a lever. If it's the other type sometimes called a crowsfoot, then put a hollow box wrench spanner on the handle that sticks out to use as a lever.
A plumber will most likely take it on as work is getting quiet in most areas, but it might be costly for you on an hourly rate as it might take him a while. Best to get a quote first.
