Discuss Triton shower handle will only turn halfway. Water is lukewarm in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi all. Sorry I'm not a plumber so go easy on me. I have a triton shower (see images) below, I don't know the model as it was here before me. Basically you have to turn the handle anto clockwise for hot water, off is the 6 o'clock position. However the handle will only go as far as between 12 o'clock and 1 o'clock. If you look at the image below that's as far as the handle will turn, meaning I can only get luke warm water. I know you can calibrate the temperature by turning the valve with an allen key, but that isn't the issue. The issue is that the handle physically wont turn far enough. Anyone familiar with this shower, any suggestions? Thank you
Likely the cartridge needs replacing, or at least some maintenance. If you email the photo to Triton or the Showerdoc, they may be able to advise further and supply the spare.
Reply to Triton shower handle will only turn halfway. Water is lukewarm in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi All Just looking for some advice on which Exposed Thermostatic Mixer Shower (Bar Shower) would go well with the Shower Pump i'm getting...
J
I have an Arteform shower valve in my bathroom - top lever for the main shower head, middle for the handheld hose and bottom is the thermostatic...
I had a shower waste today which was supplied with the tray and wouldn't tighten up, just kept slipping threads. I've had a few of these before...
Hi all, thank you so much in advance for any help. I’m always really grateful for the advice and support from experts when I have been on here a...
Hi all, Just after a bit of advice on a recent shower issue. We've had the shower installed since about 2016, and it's been relatively trouble...
Deleted member 120897
