V
Vman
Hi
Looking for a bit of advice, in a 4 year old new build with a Potterton promax SL boiler and Tribune HE 180 indirect water tank.
The water tank always sounds as though it is in operation even when the boiler is not on. The electric immersion switch is also switched off.
The pump is always absolutely scorching to touch and the two motorised valves have a very slight vibration when touched as though they are in operation and the cupboard where it is situated is like a sauna. The motorised valves are Danfoss and have two settings, auto and manual - they are both set at auto.
Is this normal?
I thought that the pump should only heat up when the timer switches on, which is set for one hour in the morning and one in the evening, and should be much cooler to the touch out with these times.
Is this normal?
