Discuss Trianco utility 65 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
Nate Pyke
No fuel coming through the injector when starting up, thought it obviously be the pump but have been told maybe not, any ideas people please ?
Oftec eng required I would say also maybe a thought of getting it services at the same time ??
Loads. From your fuel being knicked to running out of fuel to an ingress of air.
Not a lot to go on. How about a bit of a backstory to point you in the right direction.
Reply to Trianco utility 65 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
