Discuss Trianco tro mk3 what brand is the burner? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
hi guys, I removed a burner from the trianco tro it had 2 screws below the burner to keep it fitted. It had a danfoss pump on the right hand side face on and the control box on the left face, the blast tube above is a case that's opens up and the fan is in side. The fan adjustment is by a flat head screwdriver, there is no make or model and it's bare metal. Any ideas? I looked on the trianco website Andrew there is no burner matching it.
Are you sure it's a bentone?. I'm only wanting to find out the spec of burner as it's annoying me plus so I know what nozzel it requires.
I can’t be sure without seeing the burner from the front.
Nozzle size is determined by kW / BTU output of boiler.
TROs usually have a EH pattern. The exact size you can work out for yourself (see other postings on here)
If the current nozzle (size & pattern) has proven satisfactory, why not replace with like for like.
Looks like a B9 burner from the back for sure.
If it is, then the original oil pump will be a Danfoss BFP41L
and the motor will be 70 watt
Air box will be all plastic and fits in with 2 plastic lugs held with 2 Allen bolts and can easily partially block with dust
Reply to Trianco tro mk3 what brand is the burner? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ah, the joys of older home ownership (1974). We thought our major plumbing issues were dealt with when we got rid of our orangeburg sewer line and...
2K
Good afternoon everyone, I hope you're all going to make the most of the sunshine today. For those of you in front of computers, and more...
Hi, some professional advice would be greatly appreciated, We are having an Unvented Cylinder installed into our 2 bedroom ground floor flat. I...
9K
  • Locked
Hi chaps. I’d like to change the bearings in the burner motor of my Worcester Heatslave 20/25, and I’m just looking for a few helpful hints...
6K
Bunker
B
C
  • Locked
Good evening all, I am a new member to the forum, I have used the site regularly for help & advice from van shelving tips to with boiler...
4K
Bunker
B
