Discuss Towel rail valves open or closed! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
I’ve just fitted a towel rail. Should both valves be open to fill it? And stay open once filled and bleed?
Reply to Towel rail valves open or closed! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My towel rail is not electric but separate to central heating and has been working consistently but since the 2 port valve was replaced on Monday...
Hi all. The current towel rail is 1000mm x 600mm and ideally I'd like the pipes coming straight from the ground into the rail. The distance...
Hi there, Can I simply undo the screws on this heater towel rail, make sure it's off and prop it up while I paint the wall behind it? I saw...
Hi I’ve got a blockage somewhere that’s preventing the GCH bathroom towel rail from heating. Plumber has offered to try and resolve it at...
Deleted member 120897
