Discuss Tools Needed to be a Plumber in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jase158
I have the usual Pump Pliers, Adjustable spanners, Pipe Benders, Drill, 18v Drill Circular saw.
Now I wonder what else I need, as I am I get by, but I do wonder would my job be made easier if I had different tools, Now my adjustable spanners are the medium size ones, not big ones. same as with the pump pliers.
and I was replacing a pump the other day and the pump pliers did not work very well.
So I am a bit confused as to why they are called pump pliers if they do not fit pumps very well?
Any suggestions
They work better if you connect to a bicycle pump ...
Knipex are favourites on here, but are expensive.
I wouldn't do without my Bahco spanners (6" and 8" thin blades), available from Screwfix.
Reasonable screwdriver set with loads of bits and pieces including magnet - needn't cost the earth.
Stabila spirit levels (different lengths) - one of mine is a keyring which comes in handy occasionally.
Bosch PMF 180E if you're feeling flush - they're around £70 on Amazon - brilliant piece of kit which will be borrowed by others from time to time.
Wouldn't be without my wet vacuum either.
Cheers dont know it all, did have a wet vac, think this is an urgent replacement item.
cheers for the advice on everything else, will invest in these items, do you have 2 pump pliers.
I couldn't be without my Barco's 8" wide jaw adjustables, set of pipe slices 15,22 and 28mm although if you have spare money, I've just got the milwaukee 12v pipe cutter!! hardly used my slices since!! there are many sizes of pump pliers rotherbureger do a 6" set, I have a regular set and have over the years aquired a large set about 24", think there american can't remember. stilsons are always handy!! good set of screw drivers I prefer stanley ones and mostly use the long 18" posi good hacksaw and junior hacksaw, although with my pipe cutter I got the 12v hackzall, mini rip saw, hardly use a hacksaw any more. but it cost money though, I have slowly collected a good assortment of tools that will do just about any job I need to do. but I have been at it for some ten years now and my wife does think I'm a bit of a tool hoar and every time a new screwfix book arrives she " passes over my new **** mag" her words!!
my advise is buy the best you can now but don't break the bank, as in time you can get the tools you realy want, but first you have to get some work done.
cheers for the advice, my mrs has threatened to lock me in my van with a screwfix mag, she says I spend more time with them then do with her, lol
Also did you ue to use the 28mm cutters very often, I got an adjustable cutter for the larger pipe, although I couldnt imagine tight holes with the adjustable pipe cutters.
trick for getting pumps undone is use two hammers and tap either side of the nuts simultaniously moving round before you try to loosen them
not applicable to combis obviously
personally i like my foot prints grips as they lock on and dont rely on how hard you can grip takes a while to get used to the fact they only work in one direction(as do stilons) but once locked on they seldom slip ive got 12 inch ones for pump nuts
i only use pump pliers when i need the thinner jaw or i need to turn backwards
one tool i wouldnt be without is Wolfcraft 90 degree Angle Screwdriver Tool Set: Amazon.co.uk: DIY & Tools
you can get them much cheaper than that thing i paid about a tenner with 6 bits in a clip its one of those tools you dont realise how handy it is till youve got it
my other most handy tool is a smal pen knife on my key ring i keep it sharp and use it daily for opening packets slitting boiler boxes cutting the end caps of bundles of copper being on the van keys its alway there when i need it how many times have we all struggled to open someting in those infenal plastic packets
Bahco do a 12" widejaw adjustable perfect for pump nuts and monument do a pump spanner too. If the nuts seize heating with a blowlamp soon frees them.
Reply to Tools Needed to be a Plumber in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I am trying to replace my bathroom tap with a new one, I am trying to remove the existing rusty flexible tap connectors from this bit of 22mm...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked...
Hi, would be extremely grateful for any advice on the following. I'm installing a bathroom (shower, toilet and sink) in my summer house. It has...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig...
