Discuss Toilet/shower block pressure problems? in the USA area at PlumbersForums.net
Illuminate
illuminate
Where I work we have problem with the hot taps pressure and temperature is quite poor. Apparently it has been poor for a while but was once much better. It is a commercial setting toilet block which is gravity fed from commercial sized tanks. The taps are mixer taps and mixer showers and I believe but I don't know for sure that the hot and cold supply are both from the tanks. I have not checked the set up yet and I don't fully understand plumbing to this scale. The system is pumped and I assume the pump works as other more experienced staff believe it is.
I am aware of airlocks but is this something that can occur in this large size system or more common in domestic settings.
Someone said to me that they think the problem started when the place opened again after being shut a while during covid restrictions.
Any ideas or advice welcome.
High pressure taps on a low pressure system if you can best switch to individual taps
Reply to Toilet/shower block pressure problems? in the USA area at PlumbersForums.net
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
