Discuss Toilet pans 6l or 9l or not relevant? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
articoceanic
Hello
I have a 9litre toilet cistern and need to replace the pan. Can i just buy any pan or do pans come with sizes of cisterns water levels, so it doesn't overflow or something similar.
Do i need to look for a 9l toilet pan or are all the pans compatible?
thanks
p. s. if i need to look for a 9l toilet pan, could someone recommend me one. Shops don't seem to list them by soze.
You're better off buying a whole new toilet. Unless you know the specific make and model you're gonna struggle to get one to match and fit
^ As above from Riley, not all cisterns sit the same on the pan and the fixing holes can vary in postions and sizes.
Are the pan and cistern close coupled? (ie the cistern sits on a shelf moulded into the back of the pan)
Or is it low level? (cistern is separated from the pan by a short flush-pipe)
Or is it high level? (cistern is mounted high on the wall, and connected by a long flush pipe).
If its close coupled, as the advice from the lads above, replace pan and cistern together.
If its either high or low level, just go into any plumbers merchant and ask for a HO pan. They are all more or less the same, and will be fine with your 9 litre flush.
HO pan? Never that one before Ray. ( must be a southern thing :D)
Call them washdown pans, up here in the frozen north.
You should also be able to adjust the water level in the existing cistern to flush 6 litres if flushing 9 litres through the pan causes any major issues.
I don't think this will be necessary - unless for water saving practices
Funny how terminology changes over geography. HO = Horizontal outlet, to differentiate it from P trap or S trap pans.
Strictly speaking, all close coupled pans are also HO, although (at least down here) HO is used to refer exclusively to HO pans which are not close coupled, like a Armitage Magnia or Twyford Classic.
For me, "washdown" is just descriptive of a pan which relies on all the flush coming down from the rim. The alternative to "washdown" would be "syphonic".
But as you say - trade terms vary depending on where in the country you are.
We say sand and gravel. You say ballast!
Let's call the whole thing off!
Well according to google, a Dudley Tri-shell isn't close coupled, so the 9l cistern should do. You can adjust the fill height if the flush doesn't perform as expected.
+1 its not close coupled so you can just replace the pan
Reply to Toilet pans 6l or 9l or not relevant? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
