Discuss toilet pan fixing screw sleeve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
buckley plumb
hi i am sick of paying £5 for a pan fixing fischer screw kit and only end up using the plastic tapered sleeves as the screws are either to long or short . does anyone know where i could just get the plastic sleeves from
ant
i would also like to know this?? no cheapo carp, good strong materials only......... mr fischer,mr screwfix etc........ come on get it sorted out!!
ant
These days the customer has usually bought their gear on-line - I tell them to make sure there is the following:
Bette or similar quality bath pop-up (reduce risk of leak!)
Wc pan fixing screws or bolts
Basin fixing bolts
These will always be required, so get customer to supply them.
In the old days we used brass screws (3 inch 12s or similar). But I agree with OP in terms of using fisher fixing bolts which are better.
The Roca stainless screws with chromed bolt heads are also decent, but these will be £5 or there abouts.
I'm finished with buying overpriced Fischer from Scewfix, for pans I use Goldscrews with white plastic cover caps and cut down sleeves from any random hammer/frame fixer lying around.
I agree with all of you. But why get so worked up about paying for them, surely you pass the cost on to the customer.
ideal standard toilets used to come with a strip of plastic screw washers and covers i used to save the left overs of these . the screw caps and washers i have seen in shops etc are not as big as these ones in screwfix are tiny.
I sometimes use the plastic feet off old bath legs when stripping them out. The screwed rod can be fixed through a partition as well if access allows. Otherwise M8/M10 Stainless Steel coach bolts with 10mm/14mm rawl plugs or screwed into a timber dwang, or M10 Anchor bolts are very cheap and much more secure. Both are tightened with a socket wrench.
Coach Screws A2 Stainless Steel M10 x 70mm Pack of 10 | NoLinkingToThis
Shield Anchor Bolt Type 10 x 68mm Drill Size 16 Pack of 5 | NoLinkingToThis
You can buy these anchor bolts in larger packets than this and for much cheaper too.
I don't like the plastic cover things, they get soaked in urine, go yellow and then snap off leaving a place for bacteria live. Nor do I like the idea of coach bolts.
Sanitus means health, and sanitary appliances must be cleanable.
Just a tip on this. If you are screwing in brass pan screws or stainless bolts, dip the end of the screw in silicone lube - this gives you much more control over the tension of the screw, and helps to avoid cracking the pan through over-screwing.
Just use a couple of rubber tap washers on the screw followed by a stainless steel washer and the pan never cracks or better still never moves. The screw heads can be covered by a silver cup washer for appearance if required.
Galvanised or A2 rubber bonded washers with A2 screws for me. I use them to fix WC cold water cisterns to the wall too. Does the job.
Reply to toilet pan fixing screw sleeve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
  • Locked
Hi All, I am a 16 year old school leaver (Sept 23) looking for a local company to take me on as an apprentice plumber. I live in Benfleet and am...
Billy Barnard
