Discuss Toilet Leak Even When Water Turned Off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
Neilmaxx
Hi
Just installed a new close-coupled loo and noticed water around the base. No leaks from securing bolts or water inlet so I suspected it was the doughnut washer. On inspection it looked a little off centre so possibly slipped when installing it. Tried again taking extra care but same story. The doughnut is a foam one that came with the unit: should I ditch it for a rubber one, if so what would you recommend? Or should I try siliconing it into place and if so where is best to apply the silicone?
Many thanks
Reply to Toilet Leak Even When Water Turned Off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
