Discuss Toilet flush valve and ball valve in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi everyone,
The flush button on my toilet has stopped working. I have been quoted £95 to supply and fit a new flush valve and £75 to supply and fit a new ball valve. Please could someone kindly advise if this is a reasonable price?
Thank you.
It depends on who you’re using and what’s involved. If it’s the old style type which involves cutting off bolts that’s a decent price, if it’s the bayonet type flush valve then it seems steep, and steep for either type flush valve unless it’s all concealed?
Thanks for your reply. He didn’t mention about cutting bolts off, to me it looks like replacing one fluidmaster for another. He said about it needing a bigger connecting piece which are hard to find? I’ve attached a photo.
Looks easy enough, parts seem readily available - perhaps obtain a different quote from someone else?
Edit: how concealed is it? Top access only?
Looks like a low level cistern, which are easier to work on than close coupled.
Seems a bit high, especially for doing both jobs - as the second one will only take 10 minutes and you are there already.
They may have been priced like that in case you choose to only get him to do one of the jobs??
Ask what price is to do both jobs in one visit.
Reply to Toilet flush valve and ball valve in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
