Currently reading:
Toilet Flush Button Stuck
Discuss Toilet Flush Button Stuck in the General DIY Plumbing Forum area at PlumbersForums.net
For a while now one of my flush buttons on the toilet has started sticking down and so it just continues flushing. I can get it to pop back up by wiggling it around a bit but this is starting to get quite annoying.
Is there any part of the system I could easily replace myself that would fix this?
Would say it’s faulty then
worth a punt cleaning the washer just in case anything is keeping it open
You were right the valve needed flushing out, there was small bits of grit in the valve!!. After cleaning out the valve worked perfectly.
The slight problem I've got now is whoever installed the toilet pan/bowl put it slightly too close to the wall so when I flush I'm getting a leak because the 2 plastic bolts holding the cistern down onto the bowl are at a slight angle sigh Its probably why they put so much silicon on, gggrrrrrr!
Did you replace the donut washer and bolts ?
Yep but only did them hand tight, theres no leak from the water just sat in the cistern only when I flush. Also I cant get the lid back on properly as the back of the cistern is at a very slight angle. Looks like I'm gonna have to dis-assemble it all re-align/retighten. I've had enough for today so will have to look at that another time.
Is it a rubber donut or foam
No the one between the toilet pan and cistern ?
Eg like this top right rubber
https://www.NoLinkingToThis/p/wc-close-coupling-kit-white/84958
Correct you have the one that seals the flush /siphon to the cistern but your missing the one between the pan and cistern
eg
Yes aslong as it’s not damaged or misshaped
Got another problem now, I've disassembled the toilet again. When I put the old rubber doughnut over the new lock nut its loose and I don't think it should be like. Basically the diameter of the hole in the doughnut is much bigger than the diameter of the locknut. The old lock nut was a bigger diametere but will not fit on the new flush valve thread.
Does this mean I need a new rubber doughnut of a different size? The kit came with one but it said use that on the upper side of the thread because I have a 2 1/4" outlet.
I've attached photos of old doughnut and new locknut. Also my toilet didn't have those metal brackets that come in those doughnut kits.
If you can put the old one on the toilet centre it as best you can in the hole if you have any silicon grease or vaseline you can use a small amount to stop it moving around
then to the best of your ability centre the cistern over the hole and slowly lower it down onto the toilet being careful not to move the washer too much and then tighten the bolts up
try that might work if not you need a new foam or rubber donut
Be careful not to cross thread the valve
Reply to Toilet Flush Button Stuck in the General DIY Plumbing Forum area at PlumbersForums.net
