Discuss Toilet cistern not refilling in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
CHills
Hello, my cistern is not refilling after each flush however there is water trickling around the toilet bowl which doesn't usually happen.
If you fill manually the flush is fine but not refilling again.
Any idea's please?
Sounds as if the valve is stuck or blocked - turn the water off and clean it, or replace.
post a picture of the inside of the cistern so we can see what valves/parts are inside.
If you top the cistern up from a bucket, and leave it full without flushing, does the water level fall?
if there is constant water running into the pan the fill valve must be letting water in which is then running straight into the pan because the flush valve isnt working correctly
Reply to Toilet cistern not refilling in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
Morning to any Australians lurking around! Register its free, then message me, I'll sort your account out for you. We will need a moderator from...
